At first stopped working, then smell of burning circuits, now only full speed or stop, no variable, on either speed one or two. What could be the problem? Cheers
SOURCE: numark ttx with variable torque, platter turns slowly, weak torqu
More than likely one of the Drive IC's has failed, and needs to be replaced.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
SOURCE: Ground speed slows under pull at high variable speed settings.
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
SOURCE: hi--my 395 type 2 with variable speed switch wont
if the motor runs fine ande the drive shaft to the tool just stops turning, look at my previous response
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
SOURCE: My windshield wipers will not work on variable
Alarm control unit has a chip in that controls the delay wipers, this chip cost about 2 dollars, but it has to be sodered in. the whole box cost about 200 dollars. It is located behind the glove box on above the right kick plate ive been told. chip can be bought from mouser.
