Try here..
https://www.mikesreelrepair.com/
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
