Question about Bosch Dryers
Bosch Axxis WTL 5410 Ventless Dryer doesn't dry clothes at all. Any tips on how to fix the issue? Takes about 5 or 6 cycles to barely dry clothes.
    Habit-Forming:
  • 177 Answers
Does it get hot? How hot is the air coming out of it?
Posted on Sep 03, 2018
Testimonial: "It doesn't get too hot. The air coming out of it is like a humid hot air; just very moist."
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 612 Answers
SOURCE: bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Posted on Nov 17, 2009
farfield
Farley Redfield
  • 462 Answers
SOURCE: Our dryer will turn on, but won't actually
I assume it runs and this is from that stance. If it doesn't the motor has to be checked and the power coming in. In fact the dryer can run and still not have the correct power to opperate the heater.
A dryer has to have 2 things to dry clothes. 1 Air supply and exhaust, 2 Heating source. No mater if its a gas dryer or electric these 2 items are what dry the clothes..
A. If the dryer has all of these things it has to be heating and an air flow problem (kinked or dirty dryer duck, motor fan clogged with lint, vent flapper not opening...) is suspect.
B. ELECTRICAL
Assuming you have a volt meter and know how to use it properly.
These are the steps that the power and machine have to take to operate properly
1. power is correct (USA 220V across line and 115v to ground/neut) 2 hot lines with potential between them and a neutral and possible a ground
2 Door switch is closed
3 Timer switch closes and ready s power to heating element through centrifugal switch in the motor circuit after the motor is running.
4 the heating element is assumed to be good and have 220v at this point. Checking for voltage at the element will assure all before are ok and at least allowing the heater to work.
5 the heating element is controlled by 1 or more thermostats and a safety thermostat. If either of these switches do not close when the dryer is "cool" they are bad. NOTE some dryers could ahve 3 wire thermostats. These can read closed on one set and open on the other. And this is how they should be if good. But tracing the wire diagram will tell which set is closed and when.
6 if you have power, the timer contacts to the motor and the heater (separate circuits usually)are "closed", the motor runs, the cent switch "closes", the temperature operating thermostats are closed, and the heating element is good you have to have heat.
1 Check for 220V power into the dryer. If not check breakers and turn off and on several time pushing them firmly. If this is ok and 220V present step 1 is done. proceed through all steps above.
If these instructions and explanations are foreign to you I recommend you contact a local service person to check the appliance for you. There are several reasons but mostly safety. DO NOT ASSUME THE POWER IS EVER OFF. Like an unloaded gun is the only one ever in an accident, same applies to electric. The only time anyone gets hurt by electric is when the power is off. If the plug isnt in your hands and you cant see the knives its assumed hot til checked. even with a breaker thrown still check it.
If this helped you in some way please send me a good report. Thank you for using fix ya.
Posted on Nov 01, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: I have a WTL 5410
Hello Ken,
Welcome to FixYa.
Changing the pump in your WTL5410 isn't that hard, but it does require some detailed/specialized instructions. I could explain it, but I think you'd agree a detailed service manual would likely be better.
I can provide such a guide ( the same one issued to authorized techs. such as myself from Bosch ) in an attachment via email if you'd like to post an email address I can send a "pdf" right away and if you had any questions I could assist you further.
Let me know. I'll watch for your reply and send it or respond asap.
Regards,
Macmarkus :)
Posted on Nov 29, 2010
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Wte 86300US/05 dryer is not drying clothes shows f.03
This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Jan 09, 2012 | Bosch Axxis WTL 5410 Electric Dryer
The dryer is not tubbling the clothes is runs, gets hot inside but does not dry the clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 26, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
7 kg is the max this is quoted as dry load not wet halfed when wet.
May 30, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
358 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
