SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
SOURCE: My Stairmaster 4000 PT pedals
have diode on the alternator checked , check all wiring connections to be tight, is the battery ok (6 volts ) and last check the motor control board for damage and/or electrical burn
SOURCE: Replace the chain on the stairmaster 4000 pt
This video should help guide you.
Spring Pulley Chain Drive Hub Replacement Video for Stairmaster Stepper...
