Question about Blomberg Refrigerators
I bought a blomberg refrigerator last week model 2330SS and i don't know where is the button ice off. Thank you for the answer. I appreciate.
    Top Expert:
  • Blomberg Master
  • 5,476 Answers
It should tell you in the manual. If you do not have one https://www.blombergappliances.com/user-manuals
Posted on Feb 25, 2019
6ya staff
SOURCE:
Anonymous
  • 159 Answers
SOURCE: Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Posted on Aug 10, 2007
Anonymous
  • 1122 Answers
SOURCE: ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Posted on Sep 21, 2008
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Kenmore Elite Bottom Freezer Refrigerator
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Posted on Nov 30, 2008
Anonymous
  • 19 Answers
SOURCE: Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Posted on Jul 31, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: my refrigerator the evaporator keep
GE refrigerators are subject to a blown defrost heating element and thermostat.
Unplug the refrigerator,remove the freezer shelves. Remove the back wall of the freezer to access the defrost thermostat and defrost heater.
The heater is glass. It will have a dark burned appearance. The heater and thermostat both should be replaced. They come as a set.
Posted on Dec 04, 2009
I bought a BLOMBERG Refrigerator model KQD1440X and it is suddenly giving me an error 8 on the display. Can I have an explanation on the error 8 and how do I solve it?
Water inlet valve is not working properly. either not letting water through the valve the first time and now it is sticking open and letting water over fill. Replace water inlet valve.
Feb 09, 2018 | Blomberg Refrigerators
My son just bought a new Whirlpool refrig last week from Lowes and can't find the serial number. Where would it be?
Hello, Thank You for using FixYa. I will be helping you today.On the right side wall at the top of the fresh food section.So in the fridge right side look up. If there is no model or serial tag whirlpool will not honor the factory warranty. If its not there return the unit to the store.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a kenmore refrigeator with bottom freezer. #596628322200, made by Amana. I bought it used two weeks ago from a dealer. The top started getting too warm a few days ago. The Freezer was fine. I...
Hello, Thank You for using FixYa. I will be helping you today.The defrost timer is on bottom behind the front kick plate. Open freezer door remove lower grille or kick plate and you will see it.
Jun 11, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Whirlpool Side by Side Refrigerator
 it really needs to be checked in person, the last thing you need is an unreliable refrigerator.
it could be:
  •  defrost timer sticking in defrost too long
  • defrost timer not defrosting properly
  • icemaker heater staying on too long
  • among other things
let me know if you have any more details
Jul 06, 2008 | Whirlpool Refrigerators
Refrigerators Logo
774 people viewed this question
Top Blomberg Refrigerators Experts
Marvin
Marvin
RudeRude
john h
Are you a Blomberg Refrigerator Expert? Answer questions, earn points and help others
