SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
SOURCE: freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
SOURCE: frigidaire side by side frigerator freezer keeps
Your Adaptive defrost control found inside the fresh food compartment and behind the control panel where the temperature control is located is most likely the reason for the freezing up and lack of defrost. Part number 241508001 Let me know if I can help you more, Sea Breeze
SOURCE: Fridge Amana ab 2225PEK y.
Here is a resolution for your problem. It should be a very simple fix which it is in most cases
Please read the whole website provide below after clicking onto its link
http://www.educationdx.com/refrigerator-defrost-repair.html
