Cycling Logo
a
aaron j Posted on Aug 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
3 piece front crank set "size" for mongoose xr100
What size i need to replace 3 piece front crank set, "size" for mongoose xr100 mountain suspention bike
Donald Ayers-Marsh
Level 3:
  • Mongoose Master 1,389 Answers
  • Posted on Aug 29, 2018
Donald Ayers-Marsh
Mongoose Master
Level 3:
Answers
1389
Questions
0
Helped
559773
Points
6679
"Size of what? chainwheel, crank length, Bottom bracket spindle length? Not possible to say in any case, as manufacturer specs can change, even in a model year. Take to a bike co-op or bike shop for advice or search online for "replace crankset".
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Jun 14, 2009
SOURCE: front suspension to soft on mongoose xr-75
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Anonymous
  • 70 Answers
  • Posted on Apr 03, 2010
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Anonymous
  • 128 Answers
  • Posted on Apr 05, 2010
SOURCE: loose handlebars on a Mongoose XR-75 mountain bike
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Anonymous
  • 10319 Answers
  • Posted on Apr 21, 2010
SOURCE: mongoose tactic mountain bike / loose crank on
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Testimonial: "I need a special tool to remove crank /nothing Ive ever seen"
Does front handlebars go up higher on my Mongoose Maneuver Mountain Bike?
Yes, all bikes have handlebar height adjustment.
How to Adjust the Handle Bars on a Mongoose Mountain ...
DIY Mountain Bike https://www.diymountainbike.com > adjust-handle-bar...
This is done by loosening the bolt and clamp on the front of the stem. Insert a 6mm Allen wrench into the bolt head and turn until the handle bars roll freely.
How to Raise Handlebars on Mongoose Mountain Bike
mtbrules.com https://mtbrules.com > how-to-raise-handlebars-on-mo...
Oct 2, 2022 - You can adjust the handlebars from front to back by loosening the clamp bolt in the stem's front. Insert a 6 mm Allen wrench into the bolt head.
How to Raise the Handlebars on a Mongoose
SportsRec https://www.sportsrec.com > Fitness > Strength Training
Jun 29, 2011 - Other options for raising Mongoose handlebars are adding a new riser bar, which can give 1 to 5 inches of height for your handlebars. A steer- ...
Missing: maneuver ‎' Show results with: maneuver
Product Manuals
Mongoose https://www.mongoose.com > pages > product-manuals
The Mongoose owner's manual contains important safety, performance and maintenance information. Read the manual before taking your first ride on your new ...
3answers
Replacing a rear derailleur on a 21 speed mongoose aluminum alloy mountain bike xr100 need a step-by-step on how to put a Shimano derailleur on repair manual can you please help me
I had a look at the Mongoose website.
They have manual for download.
https://int.mongoose.com/pages/product-manuals
Enter the model of your bike, or look for a picture of it.
Follow the instructions....
REgards
Geoff
2answers
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
Hey, Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Check out https://gearly.org/ for more info.
Thanks.
2answers
What is the crank bearing size??
Almost all Mongoose models use the standard BSA 68.
I would write a question to them at:
http://mongoosebikes.net/mongoose-bmx-bike/20-mongoose-mode-270-v2-freestyle-bmx-bike/
This bearing should not fail during the normal life of the bicycle, unless the rider weight is over 80 Kg.
Tighten front suspention on a Mongoose 26
Look for knobs on the tops of the suspension fork legs that will probably have a + and - sign on them. Turn them in the direction of the + (usually to the right) until you are satisfied.
If you have already tried this or it doesn't give you adequate results; you may be stuck. You can occasionally find stiffer springs to put inside; but this is sometimes more costly than is desirable and a little more mechanically difficult to do on your own if you're not comfortable with disassembling and reassembling the fork.
Just a guide though: ideal suspension firmness allows for some movement when you get on the bike and will use all of it's travel on the biggest bump you encounter.
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
I have a mongoose d series mt bike i stripped the crank on the sprocket side....where can i find one
Any Bike Shop or just assess the make/model size (probably printed or embossed on the crankarm and search the web for a set. No one sells just one crank.
You'll probably need special tools to remove it.
http://www.parktool.com/blog/repair-help/categories/crank-service
I am trying to find out what size the Mongoose sx43 is. It is from 2000 and is bright yellow.
It could be one of several sizes. To determine the size you can measure the bike from the center of the bottom bracket (where the cranks install into the frame) up the seat tube to the top of the frame. This will give you the size of your bicycle.
2helpful
I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Top Mongoose Cycling Experts
vince
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
