Buy a new panel or a new TV. It may be possible to repair the connection but it all depends on details. Sometimes the cables come attached to the boards when you order a replacement part. Then again, lots of the new stuff is made to not repair. Self destruct on disassembly.
Testimonial: "Thank you!"
Unfortunately no...only fix will be to replace the panel and they cost more than the set cost new
SOURCE: Replacing a panel control board on my LG RU42PZ61...
Not an expert, but managed to fix my 47" LG plasma a few months back.
You'll probably find that the ribbons will disconnect at one end or the other. I wouldn't recommend using a tool for the job, unless it's made of a soft material - I've ripped many a ribbon by trying to use a screwdriver or similar for extra leverage - fingernails are probably the best thing to use.
Try getting under the ribbon connector at one side or another. If you're pulling pretty hard and getting no movement whatsoever, then something might be wrong, but as a rule the majority of these boards are removable - they're not glued or otherwise fastened into position.
SOURCE: TV does not boot up LG 50PC1DA
I have LG 50pc1dra i press to turn on green light come on 1sec and the red light gos on nopictur or sound?
SOURCE: We just got a 55 inch LG LED TV. How do we set it
Easiset way is to use the HDMI Connecters and ports from the Direct TV box to the HDMI port on the TV...then set the imput source to the HDMI port that you used on the back of the TV.
SOURCE: bad display panel
Might be. http://electronicshelponline.blogspot.com/. Check this link for more detail troubleshooting to Plasma displays, and make it sure.
SOURCE: LG Washer wont start, no power
I HAVE A BEKO 42WLH530HID TV, AND WHEN I TURN IT ON THE STANDBY LIGHT COMES ON BUT NO PICTURE OR SOUND, I KNOW ITS 1, OFF 3 CIRCUT BOARDS BUT DON,T KNOW WHICH ONE, CAN ANYONE HELP ?
