Cars & Trucks Logo
Graham Magill Posted on Aug 13, 2018
My Cherry Tiggo is making a whistling noise when I want to accelerate or once it goes over about 2500 rpm. It starts and idles perfectly otherwise. There is also no power. Intake manifold maybe? Tx
3 Related Answers
Anonymous
  • 359 Answers
  • Posted on Jul 29, 2008
SOURCE: Noise under intake manifold
best thing to do is to take the intake and valve covers off, its possible you may have inadvertently sucked something up and it's in you intake. That is the best solution.
No telling what it is until you take things apart and take a look. It shouldn't be too hard, make sure you get new gaskets, gaskets are cheap anyways.
Anonymous
  • Posted on May 08, 2010
SOURCE: wont accelerate past 20 mph
Check to see if your air intake is cracked or has seperated at one of the joints. If you have an after market short ram or cold air intake the piping does not always stay together and a massive influx of unfiltred air will cause this phenomenon you are speaking of. Also check for intake vaccuum leaks.
Dennis
  • 100 Answers
  • Posted on Jan 07, 2011
SOURCE: my ford ranger started making
Mass Air Flow Sensor
2007. Why is it hard to start?
Hello. It seems one or more of your car's 'fuel injectors' is/are 'flooding' your cars engine. The excess fuel 'ignites'; making the engine 'race' at high engine speed yet it won't accelerate. Good luck and keep me informed; if you want to.
3answers
My Chery tiggo 1.6tx 2010 model is jerking while I driving
It depends on how violent the jerking is? Could be as simple as a plug &/or lead breaking down or as complicated as a fuel delivery problem. Sorry not much help, but I don't have much to go on..
Making whistle noise on off on run and stopping.
There are basically two types of whistle noises.
* Whistle when you get more gas (increase RPM, put gas pedal, sometimes just idling but louder when you put more gas)
This usually intake-side leak.
Intake manifold itself, intake manifold gasket (most likely), even airfilter housing, Airflow meter housing (connector), anything where air goes to engine.
usually engine get rough or unstable idle when intake leak occur.
Engine knocking or pinging may feel.
* Whistle when you decrease RPM (engine brake, reduce speed, sometimes just idling but louder when it dropping RPM)
This usually Vacuum-side leak.
There are many vacuum hoses in engine room. even inside of cabin (heater control, etc)
Try to spot where it coming from.
Vacuum also connected to Brake servo, heater control and spark timing.
Put metal or plastic pipe (small PVC pipe will work fine) to one of your ear then isolate source of noise and find where it come from.
MY 2003 NISSAN ALTIMA SE MAKES A CLINK NOISE WHEN ACCELERATING AT ABOUT 1700 RPM AND 2500 RPM OR GOING UPHILL ,NO NOISE WHEN REV UP OR IDLE OR TAKING OFF FAST
Wheel nuts loose, or stones in hub caps, do you get the noise rolling down hill ? , if not its engine, retrace your repair.
2answers
Acceleration issues and whistling noise while accelerating
I think the problem as to do with the clutch in the transmission
Driving on the road the RPM goes higher wituout speedind
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode?http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces?http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
