SOURCE: How do you turn?
I know it is not very confortable, but you are supposed to turn it by applying pressure on handles and pulling up the front wheel.
Here is user manual
Here is website
SOURCE: Tires for Quinny Freestyle 4 Marina Stroller
If purchased in Canada call Dorel Juvenile Group customer service dept - toll free 1-800-544-1108. They will require the model number and date of manufacturing which is located on the back of the seat of the Quinny Freestyle. They will then ship the tires directly to you. I needed to replace my two front tires on my stroller and with shipping and taxes it will we $22, the tires are $8 each. I should have my tires in five to ten days. Plus the customer service representative I spoke to was polite and very helpful.
SOURCE: Folding up the Quinny Freestyle 4 Stroller
There is a little orange tab on the right hand side, lift this up and there are 2 pull up things on each side. you must pull up at same time with both.
SOURCE: Phil and Teds Sport. Front wheel either moves
First of all, I cannot tell you how frustrating the Phil & Teds instruction manual is. Our's had one half inch square pictures that were supposed to be adequate to learn how to use this. As a general suggest there are fantastic videos posted by a third part (not Phil & Teds) that are worth watching.
After several frustrating hours I can tell you exactly how to fix this:
1. Put on the rear brake
2. Sit on the ground in front of the stroller but sit slightly on one side or the other
3. Lift up the stroller so that you can see the pin that you pull to release the front wheel
4. Pull the pin slowly out about a quarter of an inch
5. You should see that there are actually two metal pins (one large, one tiny)
6. Twist the knob you pulled so that the tiny pin does not line up with the tiny circle on the inside of the knob
7. Let go of the knob
If you did this correctly, you should be able to have the front wheel locked in the swivel position even if you tillt the stroller upwards.
I hope this helps. I also hope that at some point Phil & Teds hires someone to help them with their instruction manuals. They have several clever and humorous language in them, but when the document does not serve its actual purpose the humor just becomes frustrating. For the cost of the stroller, the company should be embarrassed that its users are resorting to these online forums to help each other, although I am happy to do it.
Enjoy!
According to the manual:
To lock it into the fixed position, rotate the swivel lock until 2 straight arrows appear in the display.
