SOURCE: I have a 1997 Pontiac Grand Prix air temp sensor may be bad
the air sensor yur thinking of is usually found out front of the car on the post that supports the hood latch betwween the radiator assemblies and the oute decorative grill. go to your auto parts store like autozone and ask for the ambient air temp sensor. then if they can, ask for a diagram of its location. Its real easy to replace usually one bolt and one wire clip. Autozone has /offers these do it yourself repar guides that can help you .
SOURCE: HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
SOURCE: GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp ..
SOURCE: jandy aqualin rs air temp malfunction
Check this by swapping your air sensor with your water sensor. (Just swap the plugs) if it still reads off then you may need a new board, if this reads ok then the new sensor may be bad. Good luck.
