Ensure the door is closed securely if the Viking oven will not enter the self-clean cycle. If the door is not closed completely, the door lock cannot engage to start the self-cleaning.
https://www.hunker.com/13408313/how-to-troubleshoot-a-viking-oven
SOURCE: cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
SOURCE: Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
SOURCE: Do I remove the racks before self cleaning my
It is a matter of personal choice to whether you remove the rack`s or not, no harm will come to you from not removing them but...If they are chrome finished they will become very dull and look like bbq grills over time and in extreme cases, warp and consequently not fit well.
If they are finished with enamel to match the oven liner, don`t worry, they are designed to be left in place, even during self clean cycles.
As for how you can clean them. You can do this by removing them and with a suitable work space (a bath tub or laundry tub works great) with regular oven cleaner`s, (preferably environmentally friendly...check your local by-laws) or other household cleaners with the assistance of a scrub pad and elbow grease. Be sure and rinse them thoroughly when finished with the cleaner`s.
Hope that help`s. If so, please take a second to rate the solution provided by me here at fixya. Thank you.
Good luck.
macmarkus :)
SOURCE: how long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
