Petrol -- use a 2.2 to -2.5 mm string
electric use 1.5--2.0 mm string
First, I'm not a Craftsman representative.
* check your warranty. Call for service.
* Web site; https://www.searshomeservices.com/repair/riding-mower-repair-service?sid=HSRxMarx8447161406&utm_source=google&utm_medium=cpc&utm_campaign=hsr-DMA_Honolulu_LawnGarden_Desktop_Exact&utm_term=craftsman%20service%20center&k_clickid=5b9b8bb0-e1fd-4e8f-8be8-b72c6e49b007&gclid=EAIaIQobChMI37qxuZS23AIVxoF-Ch0AiQcXEAAYASAAEgJrsfD_BwE
* Support (with chat line); https://www.searspartsdirect.com/model-number/257799750/0247/1503810.html?searchType=modelSearch&q=257%20799750&searchTerm=257%20799750
* Parts site; https://www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts?sid=ps:GOOGLE:AE_Craftsman_BMM:General:%2Bcraftsmen&k_clickID=5b9b8bb0-e1fd-4e8f-8be8-b72c6e49b007&kenibpid=p.590.5b9b8bb0-e1fd-4e8f-8be8-b72c6e49b007.1346460&gclid=EAIaIQobChMIh5nMnJS23AIVTZN-Ch2rdAMzEAAYASAAEgJKu_D_BwE
* Note Stanley Black & Decker aquired Craftsman as of March 2017 ; https://en.wikipedia.org/wiki/Craftsman_(tools)
Sears(Official) Channel; https://www.youtube.com/user/SearsHomeService/videos
*** The following is for information only.***
* Most string wheels will indicate the string size (or range) to use.
* There may also be a recommended string (part number) on the ID label.
* Sears parts direct discontinued #4868-05 spool line; https://www.searspartsdirect.com/part-number/4868-05/0071/257.html?modelNumber=257799750&categoryName=Line%20Trimmers/Weedwackers,%20Electric&brandName=CRAFTSMAN
* Parts manual (a copy) suggests part # 86774 Spool and line ; https://www.manualslib.com/manual/497706/Craftsman-257-797901.html?page=5#manual
But I'm unable to confirm this as sears site indicates its a Kenmor heater part.
* Craftsman 85904 .095" replacement trimmer line; https://www.sears.com/craftsman-095inch-replacement-trimmer-line/p-07185904000P
* Closest match to #86774 - #85621 ; https://www.sears.com/craftsman-095inch-diameter-line-115-ft/p-07185621000P?rrec=true
* Kid replacing double twist string(32cc); https://www.youtube.com/watch?v=3ywJtaBFfiM
* Customer stringing (.065 diam) Electric; https://www.youtube.com/watch?v=uMIdRx6E-l0
* Bump head stringing (.095 diam); https://www.youtube.com/watch?v=to_DQP-XY0M
* Fuel line repair (official); https://www.youtube.com/watch?v=KB4SQXjDI7E
* Customer's review 29cc; https://www.youtube.com/watch?v=GMYaJVjQ8UQ
* Customer 32cc review; https://www.youtube.com/watch?v=utUnhAgM-88
* Customer 22cc review; https://www.youtube.com/watch?v=JsYuIyH0lJU
* Customer's repair; https://www.youtube.com/watch?v=1qvXX-wBVNQ
* Note; Recommended string size is only a suggestion. There are now "new" styles and string material that perform better than the recommended replacement.
* Call Sears or check with Lowe's for advice.
Aloha, ukeboy57
PS; Additional info
* Gas wacker tip; https://www.youtube.com/watch?v=Kf-0oyyKnB4
* Gas leaking; https://www.youtube.com/watch?v=sCY1I4YR3MM
* How Primer Bulb works; https://www.youtube.com/watch?v=jalfpoldyo0
Forums;
* Shop Your Way ; https://www.shopyourway.com/questions/1165144
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf,
I had to buy fuel lines last week.
I called the local sears parts store, and gave them the model number.
They had a rather generic bag with the correct diameter lines.
Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off.
Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb?
Thanx.
SOURCE: Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
SOURCE: I need owners manual for 25cc, 17" Craftsman
Go to www.searspartsdirect.com and have your model number ready.
