You are using cold water, right?
Actually, I use spring water from a gallon, it's room temperature. Could that be my problem?
Just tried it with water straight out of the fridge, same problem. Only steam is coming out with very minimal water/coffee. I even put coffee in there just in case that was happening because there was nothing in the filter basket, but I still have the same result.
Sorry I don't have a better suggestion. Unfortunately, sounds like it may just be wearing out ... I have one that is too (not that that helps!)
That's ok, thank you so much for trying though! I really do appreciate it! :)
SOURCE: Briel Multi-Pro Coffee / Espresso Maker
You have a leak in a connection or maybe the boiler. There is nothing you can do but find a repair shop to fix or replace the bad part.
SOURCE: When brewing, it steams and spits the water out
this is what happened to me, I didn't have the filter basket all the way down so the pot lid didn't open the valve that lets coffee flow so the coffee and grounds ran into the water resevior and plugged the filter, so I did the worst thing possible and took the filter out so the grounds got into the check valve that keeps the hot water going in the right direction. that makes it spit and sputter and brew slow.
after trying to flush it out forever I tore the metal plate on the bottom off and unhooked the rubber hoses (don't do this unless you have a needle nose pliers, you'll never get them back on) one should go to the brew head and the other is the water inlet, this has the check valve. you can tell which is which by blowing through them and seeing which one goes to the brew head. if you can blow through the other one the check valve is stuck open, I blew air into it with an air compresor and this forced the check valve shut and now it works fine. I know this is the same symptons as calcium deposits but I had cleaned it twice.
try flushing it with water first but sometimes it takes extreme measures
SOURCE: Coffee maker brews MUCH slower and makes less coffee
It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
SOURCE: Saeco Vienna not brewing
I wish I could post a solution, but this is exactly what happened to my machine after about a month of use. I don't see any clog nor a way to get to the moving parts that could create a clog. Unfortunate design.
SOURCE: I have a Delonghi espresso
Check your operating manual for decalcification. do not use vinegar you may demage the machine
you can order the product to clean and decalcifi
good luck
