Hello, Dwight -
This YouTube video may prove instructive:
https://www.youtube.com/watch?v=AJU6yjk29DU
The video shows how replace the trimmer "string" for both a bump feed trimmer and an auto feed trimmer.
This web page has illustrated directions for 3 different kinds of weed trimmers:
https://www.wikihow.com/Change-the-String-on-a-Lawn-Trimmer
Best wishes.
Arts Tree Repair Cnic will help you
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
Jim
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
