If it's a ac unit then check your blower if it's running .if running and filter clean then you might be low on refrigerant. Need to locate leaks, fixed then recharged
Unsure if that is a refrigerator or an Air Conditioner.
Please add information to your question as to the model, or whatever you can tell.
SOURCE: Dometic Quick Cool RV unit
Time to be serviced,could be a small leak and loosing freon, or low air flow due to dirty filter.,
SOURCE: Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
SOURCE: Dometic Quick Cool compressor freezing and evaporator coil
Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
