Question about Electronics - Others
How do you clear the USB card - Electronics - Others
  • Brett Duxbury
    Brett Duxbury Jul 12, 2018
    Hi Deb Whyte, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    usb card do you mean a memory stick ?
    What operating system is computer ?
    what have you tried doing to clear it ?
Usb not working with data card
A common problem is forgetting to reset the USB ports after removing a device previously. Rt Click on the white tick icon (bottom right) and check all relevant USB ports have been cleared. I personally have had big problems with cheap SD cards due to bad contacts, which can be toothbrushed with Isopropyl Alcohol or similar. Another problem is that SOME older laptops/usb SD adapters have limits on the size of data cards you can use. Check manuals &/or try using a small capacity card to check.
Apr 28, 2014 | Electronics - Others
My pendrive is write product how to remove that give me any software
If this is a SD card, slide over the 'Lock' switch on the side.
If a USB flash drive - try RMPrepUSB - Drive - Clear Read Only Status.
Oct 19, 2013 | Electronics - Others
Usb write protected removal
Sep 27, 2013 | Electronics - Others
Usb disk storage format tool
Sep 26, 2013 | SanDisk Electronics - Others
Unlock micro sd password
Sep 19, 2013 | Verbatim 2GB Swivel Drive 96836 Media
My bios can not detect usb configuration why? my usb ports can not be Used?
If you already tried to clear the bios settings of your motherboard or change the bios settings but still the same. The best solution for you is to buy a pci (Peripheral Component Interconnect) card with usb port commonly with 4 usb ports. The pci card will install on your free pci slot on your motherboard and depends with your operating system if the card will plug and play or manually install using it's driver.
Apr 22, 2013 | ASUS Computers & Internet
I HAVE A NOKIA 5130 XPRESS MUSIC HAND SET AND ITS MEMORY CARD IS NOW LOCKED .IF ANY SOLUTION FOR THIS PROBLEM?
Hi sunilkumsrmo
  • Just format your memory card ..
  • It will be cleared
  • else you don't want to lose the memory card data means go to ->this link i attached it and download that recovery software and recover the data,then you format the card the lock will be cleared....
Jan 01, 2011 | SanDisk 2GB microSD Memory Card
USB 2.0 on Intel D845PT Motherboard
HI,
Yes, that board is only a 1.1 USB port. USB 2.0 can easily be added to a computer using a USB 2.0 PCI card. These cards are relatively cheap and they can be found in almost any computer store. You can even find USB 2.0 PCI cards at Walmart. The cards will typically have 3 - 5 ports on them. These ports are setup so that you will have to plug your USB devices into the back of the computer.
Good Luck
Mark
Dec 28, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Clear memory stick
The easiest way is just select all and delete
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Electronics - Others Logo
373 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
