SOURCE: 1996 ford tauras wont start
Sounds like a fuel problem. check fuel pressure and then check for power going to the pump.Verry likley needs a new fuel pump.
SOURCE: My 2 cycle ryobi tiller won't start. It has good
Try starter fluid in the chamber and see if it starts. If so, you may need to clean your carb.
Testimonial: " You are correct it starts and runs good with a squirt of carb cleaner into the chamber. I am having the carb cleaned now."
SOURCE: my honda gcv 160 pressure
Try this website at http://forums2.gardenweb.com/forums/load/lmower/msg0312290415003.html
SOURCE: Engine runs great for 10 minutes and then stalls.
Believe
it or not, your gas cap is clogged up with dirt and debris. When a
carburetor is unable to get a constant flow of air from outside,
pressure builds up on the fuel tank. The fastest way to determine
whether or not this is the problem is as follows.
As you are
using your Mower, at that point when it begins to stall out, loosen
the gas cap so that you release the pressure that is built up in the gas
tank. If the engine begins to regain power, then you know it is a
clogged gas cap. (Simply get a small wire and clear the breathe holes in
the cap.) If the engine dies even after loosening the gas cap, then you
may want to check to make sure the air breather is clean. ( A dirty air
breather can cause the engine to over heat and stall out.)
If none of this seems to help, then it is probably a bad Ignition Coil.
Good Luck!
Jim
SOURCE: my ryobi x430 will not start. Replace spark plug and still won't start
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, 11
