Hello, Mukund -
I am answering from the USA.
There is a Stanley Black & Decker (the current name of the Black & Decker Company) business in Dubai. See the location information here:
http://placesmap.net/AE/Stanley-Black-Decker-197888/
You can contact them by phone and ask about a battery for your screwdriver.
Best wishes.
SOURCE: Black and Decker Battery Charger
Fault Codes
Meaning of Fault Code
F01
Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load.
F02
Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair.
F03
Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual.
F04
Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual.
F05
Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation.
F06
Reverse Polarity
F07
Alternator Output is Out of Typical Operation Range
Operation Codes
I=I=I=I
Battery Reconditioning - (The letters DES will display for the first three seconds)
I-I-I-I
Alternator Voltage Check
OOO
Charger Standby
FUL
Battery Fully Charged
SOURCE: My old black & decker power screw driver will
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
SOURCE: battery to fit Black & Decker CST20000 Grassho...
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
SOURCE: we need a new bread pan for our black and decker
here is a webpage with your pan:
http://www.vendio.com/stores/breadmakerguru/category/b1650/catId=3449488
SOURCE: how do I change the
The black collar should slide forward, allowing for the removal and insertion of bits.
