Ink cartridge cannot be recognized is a somewhat standard error encountered by printer users. Whether you have Epson, Canon, Brother, HP, etc; you can get this error.
Some of the tips to fix this issue:
1. Remove and Replace the cartridge again.
2. Always use Original Cartridges.
3. Check the Cartridge chip.
4. Remove the protective strips from the Cartridges.
5. Check If Cartridge Protection is Enabled.
6. Try to Reset your Printer.
Hope above solution will fix your issue. For more details you can check out the below link. https://printererrorcode.com/blog/fix-ink-cartridges-cannot-be-recognized-error/
For any issue with your canon printer you can contact. https://www.canonprintersupport247.com/blog/fix-canon-printer-error-code-5b00/ i also searched for same issues and i found this link.
When A printer not recognising a new ink or toner cartridge is one of the most common issues that print owners experience. you may have two error messages like toner is not compatible or printer cartridge not detected do these steps. Replace you new cartridge with old one. turn the printer off using it power button. first unplug and then plug it again and insert your new cartridge and prees power button. sure your printer will work properly. even if you do not get then contact Canon phone number
1 800 610 6962 Canon Printer Support Phone Number Canon Technical Support
Canon Printer Support Phone Number for Canon Printer Technical Support Services. Connect Canon Printer Customer Support Experts for Canon Wireless Printer Drivers Installation and Repair Canon Printers, Setup Canon Printer, Fix Canon printer Errors Message by Canon Printer Customer care service Number.
Canon Pixma Printer Support USA Canon Printer Support
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
SOURCE: U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must
replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
SOURCE: Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
most probably has been damaged.
ink cartrigde is damaged due to followin causes--
1. over heating of head due to bulk printing
2. mishandling the cartridge.
3. repeated refillings
try this if you want to use this cartrigde again, it may work
1. clean the golden contact points with isopropyl alcohol of cartrigde as well as the cartridge holder
2. remove cartrigde and install again after some days
possibility of fault in printer is minimal,
SOURCE: Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
