SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
SOURCE: Need replacement battery for Durabrand Portable DVD Player
Have you tried Ebay? If you used to proper charger, you shouldn't be able to "overcharge" the battery unles the charging circuit is bad. When battery is attached, will the player "ON" lite come on? Will it try to play a DVD/CD ?
SOURCE: My golf skyCaddie cannot find signal.
I am having the same issue in Ontario Canada, I read somewhere that there may be a problem with the actual GPS satellites. Where are you having the problems?
SOURCE: SG5 indicates low battery after 11 holes of golf
Issue with your Power Supply... Or Battery Need to be replace .
