SOURCE: Maytag,model mmv1153bab,serial #10001847ja,output 1000w
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, since
it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
SOURCE: I have a non-working Intermatic timer motor:
http://www.amazon.com/Intermatic-Clock-Motor-Leads-WG433-20D/dp/B0031DOHLG
http://www.nextag.com/intermatic-wg_-_433/compare-html
http://www.midlightelectric.com/acatalog/Intermatic_WG433-10D.html
I did ordinary google search for WG-433
looks like $21-33
SOURCE: how do change the
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
SOURCE: i jump my fan it works fine i change the fan
Hello koral_farver,
One common problem that fits your description is a bad blower motor resistor.
Below i will include an image of the location of the blower motor, removal and installation instructions.
The blower motor resister is under the dashboard behind the glove box.
1. Remove the glove box.
2. Disconnect the connector labeled 2
3. Remove screw labeled 3.
4. Remove the resistor labeled 1.
5. To install reverse order.
With what you have done so far by jumping the fan, installing a new switch and checking the fuses this will but you back in business.
Regards,
netvan
