I think, a sponge filter is for you - simple, cheap and effective.
It provides mechanical and biological filtration, once the sponge has grown bacterial colonies. Filters come in a variety of sizes shapes, and pore sizes to adapt them to an almost filtration need. Sponges give excellent results in ponds, saltwater, and freshwater. They can be used as an addition to another filter, such as a canister filter, or as the only source of aquarium filtration - https://great-filter.com/best-sponge-filter/
What you basically need is a multi stage filter for that much capacity. Normal filter arent that successful for mechanical and chemical filtering. But again, in multistage filters, problem of high maintenance comes up.
I wuld recommend a fluval 406 filter for that capacity meeting your requirement. For detailed review, visit https://inlandaquatics.com/fluval-406-review-specifications-features-and-advantages
The general rule of thumb is that all of the water inside your tank should pass through the filter at least four times per hour. This equation should make it easier for you to calculate. Here is an example - a 30 gallon tank needs a flow rate of 120 gallons per hour.
