We have had to completely disconnect the water bottle to stop it from pouring water.
Broken or stuck spring --bring back for repair or replacement
Testimonial: "Ok, thank you!"
What brand have you bought? I am in the market for a bottom loading water cooler too. Just found some good reviews here https://www.avidwater.com/reviews/best-bottom-loading-water-dispenser/ . So keep you posted what I go for.
SOURCE: 95 Subaru Legacy overheating, top rad hose is hot,
does your heater work? if not than your thermostat is stuck. be careful not to get the car hot as those engines are sensitive and will warp the cylinder heads quickly.
SOURCE: cooling system freelander 2001
how do i put on a water pipe on a 2002 landrover freelander? and what tools can i use to get thru the tight spot to put it on?
SOURCE: water coming back from radiator bottle
Hi Pete
This sounds like the problem could become very serious and engine damage may eventually occur . I am not a mechanic but had similar problems with my Fiat Uno a few days ago (eventually the head gasket blew) and the same scenario with the Nissan Sentra. First check the following: Does the temperature rise more than the normal mark under normal operating conditions? Is the radiator cap in order? When checking the oil dipstick is there any signs of water and oil mixing together? Lastly is there excessive steam coming from the exhaust system? If so, you could be looking at a failed head gasket. Hopefully this is not the case and there is only an airlock in the cooling system thus being solved by checking and fulling and topping up the radiator itself (if possible) with a mixture of water & antifreese whilst the vehicle is idling - and not like i did on the Sentra - by constantly filling up the coolant reservoir and the water "blows" past the cap ......hope this helps.
Good luck.
SOURCE: 2006 acura leaking water front passengerside
does your car have a sun roof . some times the rubber seals wear out and the rain will get throu and run down the channals to the floor , check all rubberseals , and roof linning for signs of wetness
SOURCE: Water/Coolant pours out of engine as soon as I put it in.
It has popped the freeze plugs out and you won't know the extent of the damage it has made till you replace the freeze plugs. You never i mean never pour water into a vehicle around time for freezing weather
