Question about IFB Washing Machines
Ifb washing machine top load E 2 error please help me
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
oldguy5
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
Anonymous
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
john_cross
  • 6277 Answers
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 13, 2011
How to remove error AC Lo error from IFB top load washing machine
The machine has detected low line voltage. Correction requires connection to an adequate power source.
Jul 31, 2018 | IFB Washing Machines
E4 error in ifb top loader machine how can we resolve it
Since you didn't include the model number I can't answer the specific question but IFB has service manuals on their webpage. Look for it here: https://www.ifbappliances.com/support/product-help/product/laundry-solutions/top-load
Jan 25, 2018 | IFB Washing Machines
I have IFB washing machine it shows E7 error
Our experienced and skilled technicians are excellent to repair the IFB Washing machine, not only IFB; they will repair all reasonable brands of Washing machines. Our IFB Washing machine Service Center can offer the services within the Hyderabad and Secunderabad zones. We can provide Doorstep service with reasonable cost. call us at 9133356801 & 9133356802. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
ifb washing machine service center hyderabad-hgqlgbgiqjunocffergste0f-5-0.jpg
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
Dear, Sir in my IFB Washing...i got a Ac Lo error hiw i fix this Error washing stopped plez give reply sir
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
126 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Raj Patel
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
