First, I'm not a General Electric Technician.
* Gear drive agitator not working or gears broken (you may hear the motor 'spin' on and off as it tries to agitate.
* Check your warranty (they can go from 3 to 5 years or even longer if you have extended service)
* Call your vendor (brand) for service.
*** the following is for information only ***
https://www.youtube.com/watch?v=D0FGSAOJdlo
https://www.youtube.com/watch?v=II_p8j-RSWU
https://www.youtube.com/watch?v=GA98ZmnzEfc
Aloha, ukeboy57
SOURCE: MY WASHING MACHINE AGITATOR WON'T SPIN. I CAN HEAR
then your motor coupling has broken cost for part is about $20 can buy from your local appliance shop or order from REPAIRCLINIC.com
SOURCE: ge super capacity plus washer. Mod wlse3150a0ww.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
SOURCE: How do I remove the
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
