Startor spins but wont ingauge its a new startor and also had it tested any ideas
If the starter spins when the key is turned to start the starter relay is good . Or do you mean the starter solenoid ? then again , if the starter spins ,the solenoid is good also. Do you know how a starter works ? Could be the bendix . Do you know what a bendix is ? If the bendix isn't kicking the pinion gear into the flywheel or flex plate , the bendix is bad . Or isn't the pinion gear contacting or meshing with the flywheel . Do you know how to check these thing's ,or could need to be shimmed .
SOURCE: 2001 mercury cougar startor problems
the best advice i can give you is to purchase a haynes repair manual at your local auto store. it'll give you step by step instructions. $18 they are usually hard to get at, but there are 2 bolts holding the starter in place, after removing the wires, just remove bolts and wiggle out. no special tools required. make sure to disconnect battery first. good luck
SOURCE: I need to find a fuse diagram for a 06 pt cruise for under hood
There is a diagram in the owners manual.
SOURCE: not starting 1975 dodge D100
check the igintion switch your bypassing it when you jump it so have it checked
