Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Good day, There is no repair possible. You could try changing the blade only, but the best repair is replacing the motor and blade as a unit. However, it is your choice on the blade only approach.
How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on
and listen for a click from the compressor relay as the compressor tries to
start.
Is the compressor motor running.If no check starter/overload
relay.
