I believe I have the same Ridgeway tent - over 20 years old. Red-, Blue- and Green-labeled poles. Best setup will require at least 2 persons. Here is a quick guide to setup:
1. First, stake the tent floor down making sure it is taut.
2. Center poles are labeled with Blue dots. There are 3 separate poles that fit through the center channel - 1 straight pole with 'male' connectors on each end (this will be in the middle), and 2 poles with curved 'female' ends. The curved ends need to slip through the center loops (there's a 'hook' to hold the loop). The center upright poles consist of a bottom pole (which should have a cap on one end and an adjustable ring on the other) and a 2-piece snap pole (with grooves on one end). Make sure to slip the pole with the grooves through the adjust ring (this will allow adjusting the height of the center of the tent). There are also 2 strings at the center of the tent about a foot above the ground. Tie these strings around the upright center pole to ensure that the center upright pole doesn't separate too far from the tent.
3. Poles with Red dots are for the ends of the tent. There is a curved 2-piece snap pole that slips through the end channel. Then, you have a 3-piece straight snap pole that attaches to each side of the curved pole. The bottom end of the straight pole should be placed about a 1.5 feet from the bottom of the center pole (at about a 45-degree angle). The door ends are essentially 'leaning' outward from the center.
4. Poles with Green dots are for the extended door cover on the large door side. These are 2 snap poles with ends that fit through the grommet holes of the cover.
Photos of erected tent are attached.
We don't use our tent very often, but my son just took it camping and it was a breeze to set up. If you still have the plastic stakes, I would recommend replacing those with metal stakes, as the plastic stakes break easily. Also, you may need to find a rain fly that fits the tent.
SOURCE: ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
SOURCE: Need replacement poles for a Kelty Gunnison 2.1
If you are in Japan it might be a bit more complicated, but your first step is to email Kelty at [email protected] and explain what happened. They may send you anew pole, or tell you where to get one, or sell you one.
22 knot winds are nothing special, and most camping equipment should be just fine in those conditions.
