I don't know.
The idea of a bypass hose is rather old-fashioned and mostly these were deleted decades ago due to the fact they slow the engine warm-up.
These days the bypass, if required is either an internal port or if the heater matrix is permanently supplied with coolant it performs the function of a bypass.
Most modern engines are fitted with a degassing system and that is perhaps what you are thinking of. Earlier types often circulated a small amount of coolant from under the thermostat to prevent gas accumulation interfering with the thermostat operation while some later types were connected above the thermostat and sometimes the radiator.
SOURCE: where is the fuse box
1 left side of dash board 2 under the hood under dash left side behind kick panel 4 owners manual
SOURCE: 1992 mazda protege valve adjustment?
on 92 models they have no ajustment,they have automatic hydraulic lash adjustment.only time youll have problems is if oil level is low or camshaft is worned out!
SOURCE: I need the firing order for a 1992 mazda protege
This is for the 1.5.L DOHC. 1-3-4-2
you can know the firing order simply by reading the numbers written on the distributer starting from 1 clockwise and they will be 1-3-4-2
SOURCE: How do you replace the water pump on a 1992 Mazda
Hi:
The water pump is driven by the timing belt, which is on the passenger side of your engine. You would need to remvoe all belts, and then the timing belt cover, and the timing belt to change your water pump.
Testimonial: "thank you."
SOURCE: 2003 Mazda Thermastat
I had the same problem a couple of years ago. It is actually located on the bottom of the engine. I have no clue why. They are usually located on the top for easy access. Follow the hose coming from the bottom of the radiator to the engine block.
