SOURCE: scope for ruger 10/22 carbine
Google SWFA ......they sell about 20 different brands of riflescopes, with pix, desriptions and prices. It's a good source for info, even if you decide to buy one of the same scopes at Walmart. Check out the Bushnell Trophy, Nikon Prostaff, and Tasco scopes, in particular.
Also, there is a website I belong to, originally started just for the Ruger 10/22 owners/fans. You can visit it and join for free at - www.RimfireCentral.com
We have a great bunch of guys and gals there, who can help you with questions on ANY type rimfire rifle. I'm sure you will love this site.
SOURCE: Ruger 10/22 Scope problem
This happens will all firearms. what happens when the bullet leaves the bullet is a decieving "rise" of the bullet. The reason for this is the Line of Sight (Scope View), angles down and away from the Line of Departure (Barrel). The bullet actually never rises and is in fact continally falling away from your rifles Line of Departure but because this is higher than the Line of Sight the bullet seems to Rise than fall to the set distance in the scope (i mention set distance and not zero because you can change your Minutes of Angle on your scope to increase and decrease range)
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this is a chart that illustrates what i just said.
now that you understand that you should take a good read into Exterior Ballistics. this is the Mathematics of your fireamrs trajectory ( I say your firearms because your bullet's flight depends on the length of the barel which will vary from gun to gun) this science of shooting will teach you how to understand bullet Grain and Volume relations. understanding the Feet per second of your rounds and how the affects you. teach you about shooting in high pressure and low pressure environments and extremly windy environment.
now there is alot of math to all of this and its hard to find it all on the net and if your not that great at math you can do what i do bc im lazy and im not a sniper im just a hobby kinda guy. '
Sierra Infinity V 6 Ballistics Software. I dl'd mine off the net you might have to buy it depending on how resourceful you are. it is well worth the buy. You can punch in the daily variables (Barometric Pressure, Temp, Humidity, and Altitude) (of couse with your bullet as well) and it will give you a "Cheat Sheet" for those conditions stating Windage and Elevation adjustments per decided incriment (50 yrds is standard) then you take that to the range and (bring a laptop if you got it and arent embarrased (som1 might even help you tune in the variables) hope this helps if not ill check back in a bit to see how you did
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
SOURCE: I just bought a winchester 308 model 100 rifle,
hELLO THERE
Please go to www.winchester.com and you will be able to enter your model number and there will be a viewable manual for this and there is also telephone numbers for tech support ok>
SOURCE: My wife has a Ruger Mini-14 patrol rifle with the
If your wife wants to use it for defense and, etc have her cowitness the optic 4moa sight with what Solution #1 suggested, instead of the normal position of the optic. Co-witnessing optics is better suited for quicker reactions, snapshots with the pekiti take off "advanced version of getting off the x"
