SOURCE: price xtr modle 70 2506 winchester
Try looking at gunbroker and see what they are selling for, give you an idea of what it is worth.
SOURCE: winchester model 70 featherweight serial
Regards,
Tony
SOURCE: What is the torque specs for a Winchester Model 70
For HVB or custom pillar bedded stock, HS Precision recommends 65 in lbs. Other 3rd party stocks are 50 in lbs and Winchester recommends 35 in lbs in the post 64 manual.
And the #Gxxxxxxx rifles have unknown manufacturing dates. They were made by a company that never said what the year ranges were on the numbers.
SOURCE: model 70 270 win will not eject spent shells
The ejector pin becomes flattened with sharp edges... it shaves brass, the brass helps stick the pin which is also penned out and a bit larger now. I took mine out and honed it so that it did not shave brass and would slide easily in the hole.... Make sure your spring is back in before you try the pin (You want something to push it back out). Most important... don't let the pin and spring get away from you. You can look on a chambered and ejected cartridge to see exactly where the bras is being shaved from. In my case it was the very back, outer flange, indicating the ejector pin.
Good luck ... hint... really use your eyes
