Tefal website:
https://www.tefal.com/faq/Products/Electrical-Cooking/Rice-cooker/8-in-1/csp/7211000792
WHY DOES THE « E0 » ERROR CODE APPEAR ON THE LED SCREEN?
The top major sensor has an open circuit or there is a short circuit. You will need to send this to a Authorised Service Centre for repair.
The sensor is the springy disc in the middle and can be replaced.
SOURCE: E0 message
It has a fuser error, needs new fuser, will not just reset when error is present.
The fuser is the hot bit that the paer goes threw to bond the image on the paper, yours has a blown heat lamp or a faulty temp sensor (thermister)
This area is not for playing in cause it is a electrical and fire hazard, just have new fuser fitted and error will be gone.
SOURCE: Tefal HA-36825 10-Cup Rice Cooker
replace the thermal fuse, it was like a resistor which is connected in the main line inside your rice cooker
SOURCE: My neolife induction cooker model 1602 shows E0
E0 means incomming voltage is higher than 260 V.
SOURCE: Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
