SOURCE: idect x1 cordless phone
the cordless connected on ups rings periodically without being called
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep. Repeat if you want mute again.
Jack
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
SOURCE: Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
