SOURCE: MOWER CONTINUES TO PULL AFTER DRIVE CONTROL IS RELEASED
try and slacken the adjuster nut on cable mate there shoul b 1 smwhere at top of cable near drive control lever/handle and also 1 at drives gearbox. failing that mate it could be a tensioner spring on the drive control mechanism
SOURCE: Tevion USB Turntable Model Number: E-E010 Purchased
Just for information i will like you to look into the track of the belt and guide it in the path as follows.
The belt normally goes around the turntable RIM at the bottom and to the spindle of the motor which is fitted on the same plane and platform.
You need not have to take out all the parts to replace but the threading of the belt around will fit correctly. The belt path can be seen well if you look on the marks left by the old one and so becomes very easy to thread.
SOURCE: drive belt diagram for 2007 husqvarna z4824
try this link to the owners manual
http://m.husqvarna.com/ddoc/HUSI/HUSI2007_USen/HUSI2007_USen_I0703908_.pdf
SOURCE: My husqvarna rz4623 is driving very slow I can't
if this has a hydra drive system it is most probably need repair as it is common for these units to fail. Have a service agent check it out but mostly the repair is by replacement.
SOURCE: What's the belt demention on a 2013 rz4623 husqvarna. The mower is discontinued
still plenty of parts available,the dimensions arent included,but you can find cheaper belts,just dont use an automotive belt,they wont last through 1 mowing,get the ones with kevlar,they r more expensive but,will last for a long time, Husqvarna Drive Belt Part 539117245
https://www.bing.com/search?q=husqvarna+539117245&PC=U316&FORM=CHROMN
your complete parts manual,,, Husqvarna RZ4623 Ride On Mower Parts
