Watches Logo
M
Myles Gellert Posted on May 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I obtain a stem and crown for a Relic ZR15841 watch?
Marvin
Level 3:
Top Expert:
  • Relic Master 85,242 Answers
  • Posted on May 14, 2018
Marvin
Relic Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29049278
Points
266281
Sorry we do not have that kind of info here.
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 24, 2009
SOURCE: i pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Anonymous
  • 93 Answers
  • Posted on Nov 03, 2009
SOURCE: My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 23, 2010
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Anonymous
  • 108 Answers
  • Posted on Apr 04, 2010
SOURCE: How do I remove the crown/stem.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Testimonial: "thanks"
Anonymous
  • 1970 Answers
  • Posted on Jun 17, 2010
SOURCE: the stem and crown fell out of my fossil watch, i
mcdevito75 here, You may not be able to fix your fossil watch, it"sa quartz and once the crown and stem came out, the mechanism that holds it in plce may be broke.
How do I remove the crown on my RELIC ZR15409 watch?
is this an mechanical watch? all the same open the back and look closely at the area near the crown stem. pull the crown out and see if any little levers move. If they do there may be a little indent on the lever. with the crown in press the indent with a needle and pull the crown our. the also may be a little arrow on the back of the movement pointing at a hole. press a pin in the hole and remove the crown.
1helpful
2answers
I have a relic brand watch model ZR11957 and can't get the back to attach properly after changing battery, how do I fix it?
Did you use a small blade and pry between the back and a small indentation on the rim of the watch to pop it off? If so, its a pressure fit. There should be a rubber gasket around the back, make sure its there and in good shape. Place the watch face down on a pad similar to a rubber computer mouse pad, properly align the case slot with the crown stem and place into position, using both thumbs push down on the back, it should snap into place.
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
Im applying pressure in the right direction but the pin wont budge
mcdevito75 here, I'm thinking you mean the stem (winder) Make sure stem is all the way in (flat on the watch) now turn the stem a little both ways, it could be locked down, if the stem turns and doesn't seem to be locked down, simply put a fingernail just under the crown and lift to set the time. If you mean the pin or spring bar to change the band, you"ll need a special tool to remove these pins or spring bars, the tool is available on ebay called a spring bar removal tool, or you can visit a small watch repiar shop in your area.
The stem and crown fell out of my fossil watch, i would like to obtain replacements and install them myself.
Jun 14, 2010 • Watches
1helpful
The stem on my relic watch has come off. Is this
This is not covered and you will have to pay for replacement.
Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Jan 28, 2010 • Watches
3helpful
I pulled on the crown and it came off the stem
Rate me, please.
Mar 24, 2009 • Watches
9helpful
2answers
How to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
