Washing Machines Logo
Bev Jurens Posted on May 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool Ultimate Care Heavy Duty-Super capacity plus washer. It will not spin nor completely drain.
Dw Wooten
Level 2:
Sergeant:
  • Whirlpool Expert 227 Answers
  • Posted on May 17, 2018
Dw Wooten
Whirlpool Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
115736
Points
551
If washer not spining are draining u might have a clog pump are pump need replaceing are u might have a problem with your motor control broad need replaceing are it might just be a lose connect on the motor control broad all these problem ca be solve by google it an they show u a video on how to fix are replace the part are just call a techican to repair your machine
3 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 23, 2009
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Anonymous
  • 278 Answers
  • Posted on Oct 16, 2009
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
richroth
Richard Roth
  • 9472 Answers
  • Posted on Mar 21, 2011
SOURCE: My whirlpool ultimate Care II Heavy Duty Super
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
7helpful
2answers
1helpful
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
2helpful
Washer spin & gurtitate no working
Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
5helpful
Won't spin or agitate
coupling.between motor and gearcase.
10helpful
2answers
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
