SOURCE: Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance. Donald McPherson Certified Watchmaker AWCI www.finewatchmaking.com
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)]. Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2. You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3. Cheers!
SOURCE: Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
SOURCE: My Tag Heuer's second hand sticks and jumps in 4
Has your display got a flashing display "BT" at the right hand side of the display? If it has, then it means that the battery needs replacing.
SOURCE: I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Testimonial: "very helpful. quick results. thanks"
