SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
un familiar with model, so am basing this on all the commercial ice makers I repair. Check the temperature probe that goes from the cct board to the ice bin if it has one ( very likely) if corroded where wire enters the stainless cap then is most likely faulty. if it is not registering correctly it can cause the unit to stop producing ice altogether or can also overproduce. It may just be a thermostat instead of a probe and again these are common items to fail. As for no water going into the unit, the solenoid valves that are used are also prone to failure of the coils and so wont open although probes / stats are always the most common fault,
If the plate is frozen solid and has oversized cubes formed, make sure the probe/stat is still attached to the evaporator plate, if it is then it will need replacing as it cant see the ice is formed, so just keeps freezing, never going to defrost to release the ice or trigger the water to come in, again very very common in commercial ice makers.
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
We suggest u to perform the following checks to solve ur problem...
thank you..
SOURCE: Kenmore ice maker problem
I'm not sure in your case if its better to order a new ice maker or if you want to take it apart and change the thermostat or possibly the limit switches. Some have a spring so if you try to do it yourself do it slowly and carefully as not to lose the internal parts. Let me know, I will help you if you need, Sea Breeze
