SOURCE: Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
SOURCE: Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
I wrote Krups to find out. Thanks for your reply
