Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
SOURCE: pls help me to fix my aircon there is error E1
E1 Code validation check fail / shut down the unit and restart.
see more Air Conditioning Fault Codes
