SOURCE: Wiring diagram for a Goldstar A/C R6004
If you remove the cover it should be on a sticker in the control area. If it's unreadable you will need to contact the Goldstar.
SOURCE: I NEED TO REPLACE A POWER CORD TO MY SMALL AC UNIT
A hardware store will have what you need to repair. Tom
SOURCE: need wiring diagram
You can usually obtain a wiring diagram 'online' just by typing in the brand of AC you have and going to a site that has Dometic AC's. Of course you will need the Model # after you get there - but I don't see you having much problem chasing down a wiring diagram after some investigation on the web.
As to wiring the motor separate. Sure, you can run a separate electrical line (needs to on a breaker to handle the amps) just for the fan, but the problem would be 'cycling' the fan. For example: presently your fan goes 'on and off' by the thermostat. But if you wire your fan on a separate circuit - you would need a way to cycle it - and you would want to cycle it with the rest of your AC. You could always install a 'on/off' switch somewhere in the RV where you could manually turn it on and off - but I would think that would be more trouble than it was worth.
What you would need to do - is to wire the motor into a separate "relay" which would be controlled by your thermostat. Here is where it get's "sticky" cause you need to know a little about electricity in order to make sure you - dot all the i's and cross all the t's.
If you are pretty good with electricity then you should be able to get a 'relay' where the 'coil' (in the relay) is the same voltage as your thermostat - and then wire the relay so it will (via the thermostat) control the "line voltage" to the fan.
If you are not (good with electricity) I would obtain the help (hire someone if you have to) of someone to assist me.
Even if you have to pay someone - you're looking at a small outlay of money. I would venture to guess - parts and labor of $150 if he/she is fair.
hope this helps
SOURCE: I have a Goldstar 10,000 BTU. Can I mount the
You should have no problems running it in that position, please rate
Testimonial: "Timely and great response."
SOURCE: my questain is can you oil or grease the fan
Usually not on these types of units. If it is squealing, it will eventually seize. You could try spraying some wd-40 on the shaft when the motor is running and then turning it off and letting the wd soak for a while. Usually when wd is sprayed on a motor with bad bearings, it will loosen all the gunk up and make the motor louder than before, but I have had kill the squeal a few times. This is an at your own risk type fix as it could make the problem worse. Best option is to buy a new motor or unit. Sometimes the motor will cost a few dollars less than a brand new unit.
