Indeed
http://www.qvc.com/IQ-America-Wireless-BatteryOperated-Motion-Sensor-LED-Spotlight.product.V33796.html
The manual is posted there..
SOURCE: Need instructionsmotion detector #5316A.
you can download instructions just type detector # on google and type manual. that should get it.
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
SOURCE: Heitage crib
If we have the same crib then I think I can help. I also bought the Heritage 3 in1 crib and am in the middle of converting it to a twin head board. I too found that the head board was much wider but you have to take the two side pieces that the crib parts attach to off(you will find the screws on the sides). But the problem that I am having now is once you take that off those side pieces they posed as the legs. So what Im thinking is that you have to screw the head board into the frame of the mattress. I havent gotten that far but I hope what I have done will help you. Let me know if this helped!!
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
