Question about Work Safety
I need instructions for 9347 child's top or vest
  • 52 Answers
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: I need instructions for Mc Calls pattern 3834 for child skirt, vest, etc.
Unfortunately, you may need to purchase a duplicate of the pattern. As long as it has the instructions, it won't matter what size it is.
Posted on Oct 18, 2016
Tip
Buy the right bulletproof vest
Whether a patrol officer, private security guard or simple civilian who needs protection from being shot, it is important to know which kind of bulletproof vest is most suitable for your situation.
First of all there are different kinds of vests.
The main general differentiation is between hard and soft body armor.
Hard body armor is made out of plates of metal or ceramic material, that are meant to stop all kinds of bullets, from rifles to shotgun slugs.
Soft body armor, instead, is made of layers of special fabrics that disperse the force of the bullet's impact. It can stop bullets from most handguns, shotgun pellets and blunt shrapnel.
After this general categorization, there are six under-categories:
Vests Level II-A, Level II, Level III-A, Level III, Level IV and Stab-Resistant vests.
Level II-A are the thinnest vests. They are soft and are designed to be worn under clothes for long periods of time.
Level II vests are the most popular among patrol offices. They can be worn both over clothes or concealed under loose clothes. They, too, are of the soft kind.
Level III-A vests are thicker, heavier and stiffer than the previous two. They are meant to protect from heavier-grain bullets and handle minor combat situations. They can still be concealed under clothes.
Level III and Level IV vests are thicker, incorporate armor plates, and are heavier than all the previous ones. They cannot be worn under clothes and are these that are usually worn by SWAT officers.
Stab-resistant vests are made with armor plates similar to those in Level III and IV and are
usually worn by prison officers to avoid being stabbed by prisoners using smuggled-in or improvised knives. They, too, reduce mobility as they add weight and bulk to the vest, but they can be worn under clothes.
Most vests allow to insert additional plates to add layers of protection, and add-ons to protect additional areas of the body.
According to your preference, you can choose a vest to be concealed under clothes or worn over them. The thinner, softer ones can easily be mistaken for undershirts, while the thicker the vest, the looser and more covering your clothes have to be to conceal it, from loose shirts to sweaters and jackets.
Make sure to pick a vest that fits you, as you want something comfortable, and not an ill-fitting vest that tends to slip, or be too small and expose vital organs to injury.
If you know that you need to protect specific parts of your body like shoulders, neck, sides or groin, there are add-ons that usually fit most vests.
If your budget is restricted, there is the option to buy used police vests that some armor dealers resell to private security and civilians. The protection they provide is the same as new ones, the only difference being their potentially lasting less time as some of the fabrics may wear out faster than in new ones.
If you need to clean bulletproof vest, using mild detergent is best, and it is absolutely recommended not to heat-dry it.
If you plan to wear your vest every day for a long time and under your clothes, you might want to wear a thin undershirt between the vest and the bare body, designed to wick perspiration away from the covered areas.
Do not test-shoot the vest as you may ruin it and prevent it from protecting you when you need it.
on Dec 29, 2013 | Work Safety
What features should I look for when buying a bullet proof vest?
When buying a bullet proof vest, you should follow these steps:
Make sure it is comfortable and allows great mobility
Make sure it provides you with maximum protection
Make sure the level of protection meets your needs
Make sure you buy it from a decent company that you can trust
Make sure the vest is adjustable
Feb 04, 2013 | Work Safety
Child craft crib model F33901.53 assembly instructions
You can locate the Child Craft crib instructions at www.child-craft.com. Assembly instructions are located to the right of the screen at the top. Once you are on this screen, you will need to only type in the five digit model number ( 33901).
I hope this is helpful to you.
Jun 11, 2012 | Child Craft Baby Gear
How to play the Laser Fighter X game by Golden bright
The gun you can fire six times before having to reload by using the "spring back reload system" on the front of the gun. You can reload the gun at any time and the reset button "empties" the gun. Each vest can take 6 shots before deactivating or loosing the game which is indicated by both lights remaining on. A warning siren will sound once your vest has been hit 5 times indicating you have on hit left. To reset the vest after the round is over turn the vest OFF and then back ON again.
The guns and the vests are independent so if you fire too close to your own vest you will "take a hit". So for this the best course of action is to fire sideways and away from your own vest.
Dec 26, 2008 | Toys
Work Safety Logo
298 people viewed this question
Top Work Safety Experts
STEVE
Johan Erasmus
Johan Erasmus
James Boyd
Level 1 Expert
Are you a Work Safety Expert? Answer questions, earn points and help others
