Customer care support service number +1--833--[272]--0777,,,,,,,call them_______
Go into Control Panel and click on SOUNDS and when the Sound Properties window opens check to see if the speakers are set right.
Hope this helps. Bud
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers.
I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line.
If there is a separate power supply the speakers are probably and either/or design.
SOURCE: Not sure which symbol is where plug in speaker dell precision workstation 420
Do you the three circle slot in the back
color green, orange and blue.
The green color is the speaker out connec the speaker socket there.
for more info:
Please see the manual here: http://support.dell.com/support/edocs/systems/ws420/en/index.htm
SOURCE: Speakers sound quiet and unclear
You probably burned tweeters and damage midranges but before disasembly check equalizer
SOURCE: interference with headphones
Have a look at the three plugs on the front tell me how it went my e-mail [email protected]
SOURCE: can i add any speakers to my dell vostro 200?
No you don't. As long as you can plug the speakers to the green port on the back of the computer, the speakers are powered and the volume knob on the speakers is turned all the way up. You should hear sound.
Also make sure the sound is not muted in windows.
SOURCE: not getting sound out of speakers
