SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
SOURCE: Just installed a new genie garage door opener.
Change the sensor and make sure the magnet comes close enough to activate it. Sometimes I have even changed the magnetic ones for real switches too.
Testimonial: "Thanks for the info. Interesting you mention a magnet. I don't see one unless its built into the carriage."
SOURCE: Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
