SOURCE: I have Heath/Zenith wireless doorbell.
"sometimes out the blue it will chime"
if for example the doorbell runs on 2.4Ghz signal and then you have a wireless phone which is also on the same frequency, everytime you use the phone the doorbell will ring. got it?
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
SOURCE: Doorbell frequencies.
in the transmitter and receiver, You will see a small box or circle with a flathead screw inside. Turn this one 1 whole turn clockwise or counter clockwise. Fine tune the transmitter or receiver so it will have max range. (higher frequency travels further, which is good info if you want to increase range.
