SOURCE: How do I take gas tank off of a Husqvarna 125B gas
Hello . First you have to remove the 3 nuts holding the plastic back part . 2 nuts are on the bottom and one at very top of the machine .
Then you just have to remove the 3 phillips head screws holding the tank and remove the fuel line . Hope this help .
SOURCE: my leaf blower will start but wont run
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
SOURCE: husqvarna leaf blower won"t start,changed the plug and gas,now what
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
