Singer machines have the serial number mounted on the top of the flat bed on the right-hand side (front of the machine). See https://www.singermachines.co.uk/faq/finding-model-from-serial-number/ for a picture of the serial number location. This is the hand-wheel side of the machine. If the machine is in a built-in cabinet that covers this area, you may need to remove the housing. Some old machines could have had the rivets damaged and lost the serial number plate.
I hope this helps.
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
SOURCE: Singer Sewing machine
I found the same numbers on my Singer, but learned that the 13608M is not the serial number. I finally found it on the bottom of the machine. It typically begins with either a single or double letter. You can find the Serial No. and Year of Issue at http://www.singerco.com/support/serial_numbers.html. You can also order a replacement manual. Another helpful site might be http://www.ismacs.net/Singer/singerdates.html.
Good luck.
SOURCE: Manual for 1908 singer sewing machine
Hi Lorraine
I too have an old treadle machine . What my Dad did for me was go to a Harness repair shop and have them cut a piece of narrow leather and that became my belt, take it home and and replace the belt you now have or you can shorten the one you do have , but not too snug,around the wheels , need a bit of slack,,, join the 2 ends together by using a shape needle or whatever it takes to make the hole in the ends of the leather and use a fine strong wire to fasten the ends to meet, looks rough but it works.
SOURCE: where can find the instrution of singer eletronic
try googling singer sewing machines with model number
SOURCE: I can 't seem to find my manual for my Singer
Poking around on the Interweb I find this is also known as a model 6510. I couldn't find anyplace to download a copy for free but there are a number of sites where it's available for purchase. This place is one; if you're outside the US you can search for a different vendor.
Hope this helps! Thanks for using Fixya.
Testimonial: "WOW! Thanks so much! I'll check this information out."
