My top oven (VIking double wall) won't turn on, light blinks, and fan won't turn off.
SOURCE: Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
SOURCE: top burners on our Viking work fine, however the
Hi, There is a good chance the ignitor is bad. Even if it glows, it could be weak enough that it will not open the gas valve. It is very a common problem with the gas stoves.
I would change the ignitor.
Vic
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
SOURCE: Are there fuses in an Eaton Viking wall oven
you have lost one leg of input power that gives you 240 volts check both legs for 120 volts each for a total of 240 volts
